주요 콘텐츠로 건너뛰기
ASUS MeMo Pad FHD10 Headphone Jack Replacement
필요한 것
  1. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 2 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 3 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 4 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 4 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Speakers: 5 단계, 이미지 1개 중 1개
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 7 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 7 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 7 단계, 이미지 3개 중 3개
    • Gently use your hands to remove the speakers.
  8. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the five screws using a Phillips #00 screwdriver.
  9. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 9 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 9 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Headphone Jack Replacement: 9 단계, 이미지 3개 중 3개
    • Carefully disconnect the cord that connects the on/off button to the motherboard
    • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
  10. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 10 단계, 이미지 1개 중 1개
    • Use your hands to remove the motherboard from the device.
  11. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: 11 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Using a soldering gun, desolder the headphone jack from the motherboard at each connection to the motherboard.
    • If you have never used a soldering gun before, check out iFixit's guide for soldering and desoldering.
  12. ASUS MeMo Pad FHD10 Headphone Jack Replacement: 12 단계, 이미지 1개 중 1개
    • Gently, disconnect the headphone jack.
    • Allow the soldering to cool off before disconnecting.
결론
작성자
10다른 기여자 명과 함께
Dmitry
회원 가입일: 01/21/15
391 평판
안내서 3개를 작성함
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G5
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 2
전체 시간: 1,457
