소개
If the screen is damaged, or has an incorrect display, it should replaced. The following is a comprehensive guide for replacing the screen.
도구
부품
지정된 부품이 없습니다.
Flip the laptop on its back side with the battery facing toward you.
Slide the tabs with lock/unlock symbol, to the unlock position.
Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
다른 한 분이 해당 안내서를 완성하였습니다.
