주요 콘텐츠로 건너뛰기
ASUS Q405U Battery Replacement
필요한 것
  1. ASUS Q405U Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Battery Replacement: 2 단계, 이미지 1/1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Battery Replacement: 3 단계, 이미지 1/3 ASUS Q405U Battery Replacement: 3 단계, 이미지 2/3 ASUS Q405U Battery Replacement: 3 단계, 이미지 3/3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  5. ASUS Q405U Battery Replacement: 5 단계, 이미지 1/1
    • Once all screws are removed, lift the battery out from the base of the computer.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 2명이 해당 안내서를 완성하였습니다.
Jeremiah Baselice
회원 가입일: 10/25/21
569 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G8
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 49
전체 시간: 1,580
