주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Q536F Screen Replacement
필요한 것
  1. ASUS Q536F Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 ASUS Q536F Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
    댓글 쓰기
  2. ASUS Q536F Screen Replacement, Display Assembly: 2 단계, 이미지 1개 중 1개
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
    댓글 쓰기
  3. ASUS Q536F Screen Replacement: 3 단계, 이미지 3개 중 1개 ASUS Q536F Screen Replacement: 3 단계, 이미지 3개 중 2개 ASUS Q536F Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
    댓글 쓰기
  4. ASUS Q536F Screen Replacement, Screen: 4 단계, 이미지 3개 중 1개 ASUS Q536F Screen Replacement, Screen: 4 단계, 이미지 3개 중 2개 ASUS Q536F Screen Replacement, Screen: 4 단계, 이미지 3개 중 3개
    • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
    • Use an iOpener to help loosen the adhesive on the screen.
    • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
    • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
    댓글 쓰기
  5. ASUS Q536F Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully remove the screen from the rest of the display.
    • The new screen should come with the sticky adhesive.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Adra Ledward
회원 가입일: 09/07/23
557 평판
안내서 5개를 작성함
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 회원
GCC-GONZALEZ-F23S88G8
5 회원들
안내서 6개를 작성함
1가이드 댓글
I've never had to do a screen replacement but I know my way around PCs. Laptops not as much, but have done other smaller repairs. Replacing the entire screen has me quite anxious. Whats the difficulty level on that?
Acrillix Official - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 35
전체 시간: 784
