주요 콘텐츠로 건너뛰기
ASUS TUF Gaming FX505GT Battery Replacement
필요한 것
  1. ASUS TUF Gaming FX505GT Battery Replacement, Battery: 1 단계, 이미지 1/2 ASUS TUF Gaming FX505GT Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Shut down the device completely by pressing the power button for about five to ten seconds, and unplug the charger.
  2. ASUS TUF Gaming FX505GT Battery Replacement: 2 단계, 이미지 1/3 ASUS TUF Gaming FX505GT Battery Replacement: 2 단계, 이미지 2/3 ASUS TUF Gaming FX505GT Battery Replacement: 2 단계, 이미지 3/3
    • Gently flip the laptop so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 14 mm screws found on the bottom and the left and right sides of the laptop.
    • Remove the five 7 mm PH1 screws found on the top and middle of your device.
  3. ASUS TUF Gaming FX505GT Battery Replacement: 3 단계, 이미지 1/2 ASUS TUF Gaming FX505GT Battery Replacement: 3 단계, 이미지 2/2
    • Use a spudger to pry the back panel from the laptop.
    • Work around the perimeter between the back case and the base, releasing any clips as you go.
    • Remove the back cover.
  4. ASUS TUF Gaming FX505GT Battery Replacement: 4 단계, 이미지 1/2 ASUS TUF Gaming FX505GT Battery Replacement: 4 단계, 이미지 2/2
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
  5. ASUS TUF Gaming FX505GT Battery Replacement: 5 단계, 이미지 1/2 ASUS TUF Gaming FX505GT Battery Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the 7 mm screw securing the battery.
    • Carefully lift the battery out of the laptop.
결론
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide. Take your e-waste to an R2 or e-Stewards certified recycler.
Matthew Harewood
회원 가입일: 02/07/24
121 평판
안내서 1개 작성함
York University, Team M-4, Allen Winter 2024 York University, Team M-4, Allen Winter 2024 회원
YORK-ALLEN-W24SMG4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 36
전체 시간: 87
