주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Transformer Book Flip TP500LA Fan Replacement
필요한 것
  1. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: 1 단계, 이미지 3개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: 1 단계, 이미지 3개 중 2개 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
    댓글 쓰기
  2. ASUS Transformer Book Flip TP500LA Fan Replacement: 2 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
    댓글 쓰기
  3. ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: 3 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
    댓글 쓰기
  4. ASUS Transformer Book Flip TP500LA Fan Replacement: 4 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
    댓글 쓰기
  5. ASUS Transformer Book Flip TP500LA Fan Replacement: 5 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
    댓글 쓰기
  6. ASUS Transformer Book Flip TP500LA Fan Replacement: 6 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
    댓글 쓰기
  7. ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: 7 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: 7 단계, 이미지 2개 중 2개
    • Unscrew the six 5 mm Phillips #0 screws.
    댓글 쓰기
  8. ASUS Transformer Book Flip TP500LA Fan Replacement: 8 단계, 이미지 3개 중 1개 ASUS Transformer Book Flip TP500LA Fan Replacement: 8 단계, 이미지 3개 중 2개 ASUS Transformer Book Flip TP500LA Fan Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Grasp the top of the 3-pin connector with tweezers.
    • Wiggle the connector until it loosens itself from the motherboard.
    • Gently lift the connector from the motherboard attachment.
    댓글 쓰기
  9. ASUS Transformer Book Flip TP500LA Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully lift the fan off the motherboard.
    • Attached to the fan is thermal pasting that needs to be reapplied when attaching the fan back to the motherboard. Follow this guide to reapply thermal pasting correctly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Solomon Dovinh
회원 가입일: 04/10/17
435 평판
안내서 2개를 작성함
Cal Poly, Team S13-G5, Forte Spring 2017 Cal Poly, Team S13-G5, Forte Spring 2017 회원
CPSU-FORTE-S17S13G5
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 2,276
