주요 콘텐츠로 건너뛰기
ASUS VivoBook S400C CPU Fan Replacement
필요한 것
  1. ASUS VivoBook S400C CPU Fan Replacement, Remove the Bottom Cover: 1 단계, 이미지 1/1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C CPU Fan Replacement: 2 단계, 이미지 1/2 ASUS VivoBook S400C CPU Fan Replacement: 2 단계, 이미지 2/2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C CPU Fan Replacement, Disconnect the Battery: 3 단계, 이미지 1/1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C CPU Fan Replacement, Heat Shield: 4 단계, 이미지 1/2 ASUS VivoBook S400C CPU Fan Replacement, Heat Shield: 4 단계, 이미지 2/2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: 5 단계, 이미지 1/3 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: 5 단계, 이미지 2/3 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: 5 단계, 이미지 3/3
    • Unplug the fan.
    • Grasp the plug with a fingernail on either side and pull it straight out from the connector.
  6. ASUS VivoBook S400C CPU Fan Replacement, Remove the Fan and Heatsink Screws: 6 단계, 이미지 1/1
    • Remove the two 5 mm screws securing the fan.
    • Remove the four 3 mm screws securing the heat sink.
    • Removing the screw covered by the warning label will void your warranty.
  7. ASUS VivoBook S400C CPU Fan Replacement, Remove the Fan and Heatsink: 7 단계, 이미지 1/1
    • Lift the fan and heatsink straight up to remove it.
    • Before reassembly it is essential to clean off the old thermal paste from the processor and the heatsink and to apply new. How to apply thermal paste explains how.
  8. ASUS VivoBook S400C CPU Fan Replacement, CPU Fan: 8 단계, 이미지 1/2 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan: 8 단계, 이미지 2/2
    • Flip the assembly over and peel off the tape wrapped around the edge of the fan.
  9. ASUS VivoBook S400C CPU Fan Replacement: 9 단계, 이미지 1/3 ASUS VivoBook S400C CPU Fan Replacement: 9 단계, 이미지 2/3 ASUS VivoBook S400C CPU Fan Replacement: 9 단계, 이미지 3/3
    • Starting at one end, carefully peel off the tape securing the heatsink to the lip of the fan.
  10. ASUS VivoBook S400C CPU Fan Replacement: 10 단계, 이미지 1/1
    • Separate the fan from the heatsink.
  11. ASUS VivoBook S400C CPU Fan Replacement, Clean the Heatsink: 11 단계, 이미지 1/2 ASUS VivoBook S400C CPU Fan Replacement, Clean the Heatsink: 11 단계, 이미지 2/2
    • Clean the old thermal paste off the heatsink until it is spotless.
  12. ASUS VivoBook S400C CPU Fan Replacement, Clean the CPU: 12 단계, 이미지 1/2 ASUS VivoBook S400C CPU Fan Replacement, Clean the CPU: 12 단계, 이미지 2/2
    • Carefully remove the old thermal paste from the CPU. It is not vital to get the old paste off the parts of the chip under the Kapton tape, but be obsessive about cleaning the silicon chip itself and the area immediately next to it.
    • Do not fail to apply new thermal paste to the processor before reinstalling the heatsink. Failure to do so could lead to overheating and the possible death of your processor.
결론
Jerry Wheeler
회원 가입일: 03/21/22
58,494 평판
안내서 69개 작성하였습니다
Oregonians Oregonians 회원
Community
8 회원들
안내서 176개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 14
전체 시간: 385
