주요 콘텐츠로 건너뛰기
ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement
필요한 것
  1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Battery: 1 단계, 이미지 1/1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 2 단계, 이미지 1/2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 2 단계, 이미지 2/2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 3 단계, 이미지 1/3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 3 단계, 이미지 2/3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 3 단계, 이미지 3/3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 4 단계, 이미지 1/3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 4 단계, 이미지 2/3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 4 단계, 이미지 3/3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. 주의: 5-6 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: 5 단계, 이미지 1/2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: 5 단계, 이미지 2/2
    • When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
    • Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
  6. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 6 단계, 이미지 1/2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 6 단계, 이미지 2/2
    • Carefully remove the motherboard.
    • You can now replace it with a new motherboard or perform any necessary modifications to it.
  7. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Charging Port: 7 단계, 이미지 1/1
결론
Jens Peter Andersen
회원 가입일: 10/03/17
658 평판
안내서 6개 작성하였습니다
USF Tampa, Team S5-G1, Walkup Fall 2017 USF Tampa, Team S5-G1, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 999
