주요 콘텐츠로 건너뛰기
ASUS ZENFONE 3 Zoom Motherboard Replacement
필요한 것
  1. ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Use the sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 3 단계, 이미지 1/2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 4 단계, 이미지 1/1
    • Utilize the PH #00 attachment to remove the 3.3 mm screws in the bracket to the top left of the battery.
  5. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 5 단계, 이미지 1/1
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 6 단계, 이미지 1/2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 7 단계, 이미지 1/1
    • De-solder the single black speaker wire attached to the left side of the phone.
  8. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 8 단계, 이미지 1/2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: 8 단계, 이미지 2/2
    • Use the flat-edge side of iFixIt plastic spudger to detach both the ribbon connectors off the motherboard at their connection point.
  9. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery, and remove the motherboard.
  10. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 10 단계, 이미지 1/1
    • The finished product should be a motherboard with no connections to the body of the phone.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Saif Aiman
회원 가입일: 07/08/19
243 평판
안내서 1개 작성함
IUPUI, Team S2-G3, Harley Summer 2019 IUPUI, Team S2-G3, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S2G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 759
