주요 콘텐츠로 건너뛰기
ATT EL52300 LCD Screen on Handset Replacement
필요한 것
  1. ATT EL52300 LCD Screen on Handset Replacement, Battery: 1 단계, 이미지 2개 중 1개 ATT EL52300 LCD Screen on Handset Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 LCD Screen on Handset Replacement: 2 단계, 이미지 1개 중 1개
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 LCD Screen on Handset Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 ATT EL52300 LCD Screen on Handset Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 LCD Screen on Handset Replacement: 4 단계, 이미지 2개 중 1개 ATT EL52300 LCD Screen on Handset Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 LCD Screen on Handset Replacement: 5 단계, 이미지 2개 중 1개 ATT EL52300 LCD Screen on Handset Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: 6 단계, 이미지 2개 중 1개 ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: 6 단계, 이미지 2개 중 2개
    • The motherboard is connected to the ringer, which is clipped on to the back plate of your handset.
    • Pop off the indicated clip using a pointed tweezer.
    • With the motherboard disconnected from the back plate, turn it over so that the screen is facing you.
  7. ATT EL52300 LCD Screen on Handset Replacement: 7 단계, 이미지 3개 중 1개 ATT EL52300 LCD Screen on Handset Replacement: 7 단계, 이미지 3개 중 2개 ATT EL52300 LCD Screen on Handset Replacement: 7 단계, 이미지 3개 중 3개
    • To get to the connection between the display and the motherboard, remove the casing for the display using a plastic opening tool.
    • The white casing has a hole cut into it. You are going to slide the display and the speaker through this hole.
  8. ATT EL52300 LCD Screen on Handset Replacement: 8 단계, 이미지 1개 중 1개
    • The display has a line of soldered connections to the motherboard. These all need to be undone with a soldering tool, so the screen can be removed.
    • Please refer to the 연결부 납땜 및 납제거 방법 for soldering help.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Katty
회원 가입일: 08/27/15
340 평판
안내서 3개를 작성함
USF Tampa, Team 1-1, Sullivan Spring 2016 USF Tampa, Team 1-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 604
