주요 콘텐츠로 건너뛰기
ATT EL52300 Speaker Replacement
필요한 것
  1. ATT EL52300 Speaker Replacement, Battery: 1 단계, 이미지 1/2 ATT EL52300 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Speaker Replacement: 2 단계, 이미지 1/1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 Speaker Replacement, Motherboard: 3 단계, 이미지 1/2 ATT EL52300 Speaker Replacement, Motherboard: 3 단계, 이미지 2/2
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 Speaker Replacement: 4 단계, 이미지 1/2 ATT EL52300 Speaker Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 Speaker Replacement: 5 단계, 이미지 1/2 ATT EL52300 Speaker Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 Speaker Replacement, Speaker: 6 단계, 이미지 1/1
결론
Eddie Barnes
회원 가입일: 02/10/16
323 평판
안내서 1개 작성함
USF Tampa, Team 1-1, Sullivan Spring 2016 USF Tampa, Team 1-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 8
전체 시간: 376
