소개
This is a step-by-step guide to replace the motherboard of your Abask J05 dashcam.
The motherboard is the main circuit board of the dashcam, allowing for communication between its various parts. In the event that parts of your device remain non-functional even after troubleshooting and repairs, you may need to replace your motherboard. Before you replace your motherboard, be sure to check the troubleshooting guide, as your problem might not warrant replacement.
Note: This guide requires the use of a soldering iron. Be sure to read the Soldering Guide for instructions on how to operate the device.
필요한 것
Gently press on the SD card with a fingernail until it clicks.
Release, then remove the card.
Remove the two 7 mm screws on the side of the motherboard with a Phillips #00 screwdriver.
Slowly pull up on each corner of the motherboard, stopping when the corner pops loose of the anchor.
Repeat the process with each corner before slowly pulling up on the board to detach the glue on the underside.
To reassemble your device, follow these instructions in reverse order. (Note: When doing the steps in reverse order, do not do Step 5. Instead, place the front face of the device back on the main body before lining up the endcap, ensuring proper orientation with the SD card slot, and push in until you hear all four snap joints snap into place.)
다른 한 분이 해당 안내서를 완성하였습니다.
