주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315-24P-R7VH Battery Replacement
필요한 것
  1. Acer Aspire 3 A315-24P-R7VH Battery Replacement, Lower Case: 1 단계, 이미지 1/1
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Battery Replacement: 2 단계, 이미지 1/2 Acer Aspire 3 A315-24P-R7VH Battery Replacement: 2 단계, 이미지 2/2
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Battery Replacement: 3 단계, 이미지 1/1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Battery Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Grip the white battery connector and pull it directly out of its socket.
    • Do not pull on the wires.
  6. Acer Aspire 3 A315-24P-R7VH Battery Replacement: 6 단계, 이미지 1/2 Acer Aspire 3 A315-24P-R7VH Battery Replacement: 6 단계, 이미지 2/2
    • Unscrew the four 4.5 mm Phillips head screws that secure the battery.
  7. Acer Aspire 3 A315-24P-R7VH Battery Replacement: 7 단계, 이미지 1/2 Acer Aspire 3 A315-24P-R7VH Battery Replacement: 7 단계, 이미지 2/2
    • Lift the battery up and out of the chassis.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Patrick Smith
회원 가입일: 09/13/23
197 평판
안내서 1개 작성함
Gateway, Team 1-1, Pee Fall 2023 Gateway, Team 1-1, Pee Fall 2023 회원
GCC-PEE-F23S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 67
전체 시간: 296
