주요 콘텐츠로 건너뛰기
Acer Aspire E5-571 Keyboard Replacement
필요한 것
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire E5-571 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire E5-571 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire E5-571 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
daniel sawyer
회원 가입일: 08/23/15
2,602 평판
안내서 5개를 작성함
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 회원
USFT-MEIER-F15S4G2
3 회원들
안내서 5개를 작성함
댓글 4개
keyboard cable is a b$%*h
shrs - 답글
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - 답글
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - 답글
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 45
전체 시간: 12,447
