주요 콘텐츠로 건너뛰기
Acer Aspire One 722 Battery Replacement
  1. Acer Aspire One 722 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Battery Replacement: 2 단계, 이미지 1/1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Battery Replacement: 3 단계, 이미지 1/1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Battery Replacement: 4 단계, 이미지 1/2 Acer Aspire One 722 Battery Replacement: 4 단계, 이미지 2/2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Battery Replacement: 5 단계, 이미지 1/1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
    Thanks-gr8 guide
    hotcatz - 답글
    Thanks for the easy to follow instructions and for the great pictures. That made everything easy.
    Siegfried Harrison Ph.D. - 답글
결론
다른 12명이 해당 안내서를 완성하였습니다.
Christian Barboza
회원 가입일: 10/25/15
818 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G6
3 회원들
안내서 10개 작성하였습니다
댓글 4개
First rate easy to understand completed in less than a minute.many thanks
Alan Fowler - 답글
I find myself computer savvy. These steps jarred my memory. They were perfect.
scolan910 - 답글
Thank you, you are a hero of 2021.
Athirah siagian - 답글
Thank you. Simple, yes, but a little encouragement always helps.
Wade Stanfill - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 52
전체 시간: 12,317
