주요 콘텐츠로 건너뛰기
Acer Aspire R7 Battery Replacement
필요한 것
  1. Acer Aspire R7 Battery Replacement, Cover: 1 단계, 이미지 1/1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: 2 단계, 이미지 1/3 Acer Aspire R7 Battery Replacement: 2 단계, 이미지 2/3 Acer Aspire R7 Battery Replacement: 2 단계, 이미지 3/3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: 3 단계, 이미지 1/1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: 4 단계, 이미지 1/2 Acer Aspire R7 Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: 5 단계, 이미지 1/3 Acer Aspire R7 Battery Replacement: 5 단계, 이미지 2/3 Acer Aspire R7 Battery Replacement: 5 단계, 이미지 3/3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
결론
다른 12명이 해당 안내서를 완성하였습니다.
F Fernandez
회원 가입일: 01/13/15
435 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G4
4 회원들
안내서 7개 작성하였습니다
댓글 6개
What is the battery reference for replacement ?
skalpinou - 답글
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - 답글
hey how do you want då sel it for
Alex santos - 답글
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 50
전체 시간: 41,192
