주요 콘텐츠로 건너뛰기
Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement
필요한 것
  1. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement, USB Port: 1 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement, USB Port: 1 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement, USB Port: 1 단계, 이미지 3/3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 2 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 2 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 2 단계, 이미지 3/3
    • Remove the yellow tape from the circuit board that is connected to the USB port.
    • Carefully unplug the two bundled cable connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 3 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 3 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 3 단계, 이미지 3/3
    • Flip up the ZIF connector that holds the larger ribbon cable in place with the opening tool.
    • Carefully unplug the larger ribbon cable by pulling on its blue tab.
  4. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 4 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 4 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 4 단계, 이미지 3/3
    • Flip up the small ZIF connector that holds the smaller ribbon cable in place with the opening tool.
    • Carefully unplug the smaller ribbon cable by pulling on its blue tab.
  5. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 5 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 5 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 5 단계, 이미지 3/3
    • Remove the 3, 2.5 mm screws on the circuit board.
  6. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 6 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 6 단계, 이미지 2/2
    • Remove the 2, 4.25 mm screws on the security tab.
  7. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 7 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 7 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 7 단계, 이미지 3/3
    • Lift the security tab so that it will be out of the way when you remove the circuit board.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  8. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 8 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 8 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: 8 단계, 이미지 3/3
    • Remove the circuit board by lifting it up with the opening tool.
    • The USB port is attached to this circuit board you have just removed. To replace the USB port on this piece, please go to the page How To Solder and Desolder Connections.
결론
Grecia Corrada
회원 가입일: 03/19/18
1,134 평판
안내서 6개 작성하였습니다
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 회원
BU-WILLIAMS-S18S3G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 19
전체 시간: 1,588
