주요 콘텐츠로 건너뛰기
Acer Aspire V5-473P-5602 Touchpad Replacement
필요한 것
  1. Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: 2 단계, 이미지 1/2 Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: 2 단계, 이미지 2/2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Touchpad Replacement: 3 단계, 이미지 1/1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Touchpad Replacement: 4 단계, 이미지 1/1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Touchpad Replacement, Touchpad: 5 단계, 이미지 1/1
    • Use a spudger to remove the aluminum foil tape from the touchpad.
  6. Acer Aspire V5-473P-5602 Touchpad Replacement: 6 단계, 이미지 1/1
    • Unplug the cable from the touchpad.
  7. Acer Aspire V5-473P-5602 Touchpad Replacement: 7 단계, 이미지 1/1
    • Remove ten Phillips #0 screws securing the touchpad to the base.
  8. Acer Aspire V5-473P-5602 Touchpad Replacement: 8 단계, 이미지 1/1
    • Use the pointed end of a spudger to remove the small triangular metal piece.
  9. Acer Aspire V5-473P-5602 Touchpad Replacement: 9 단계, 이미지 1/2 Acer Aspire V5-473P-5602 Touchpad Replacement: 9 단계, 이미지 2/2
    • Use the spudger to lift up the touchpad carefully.
    • Remember to use electronic cleaner to clean the touchpad screen surface before placing the new touchpad back in.
결론
Thuy Tran
회원 가입일: 01/22/20
267 평판
안내서 2개 작성하였습니다
York University, Team S8-G6, Turner Winter 2020 York University, Team S8-G6, Turner Winter 2020 회원
YORK-TURNER-W20S8G6
5 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 337
