소개
Acer Aspire - V5-572, V5-572G
Follow this guide if you want to change / upgrade your HDD (Hard Disk Drive) or install SSD (Solid State Drive).
필요한 것
동영상 개요
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
I have to agree that this is extremely complicated and intense.
There is no way your average user should be doing this and the average user should be able to replace the battery!!
Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
Sucks!!
다른 3명이 해당 안내서를 완성하였습니다.
댓글 7개
ashmir, you just clone your HDD with a free software such as Macrium Reflect and don’t need to worry about installing everything from zero!!!
Thank you for the tutorial.
But need a clarification. If i have a faulty hard disc it starts up but it freezes after 20 minutes.
Is it still possible to clone it.
Also if i change the hard drive do I need to install any software or the bios all over again.
Your inputs will be appreciated.
I haven’t had much luck cloning hard drives that already showed signs of failure, but it costs nothing to try. Download something like Macrium Reflect (free version) and plug the new drive into an external enclosure, and see if it will clone successfully.
Can i add ssd and keep my hard drive?
Please somebody answer my question!
