주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C3WS Screen Replacement
필요한 것
  1. Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Using an iFixit opening pick, pop off the bezel from around the screen, beginning on one side and continuing around the whole screen.
    • Remove the barrier from the front of the screen.
  2. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Starting in the top right of the screen, remove the six 4mm JIS #0 screws that secure the computer screen to the top.
    • There will be two sets of two screws on the top, one screw on each side of the bottom of the screen.
  3. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the screen down, and lay it flat against the keyboard.
  4. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the input connector from the screen.
  5. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Samantha Postma
회원 가입일: 10/15/19
1,238 평판
안내서 6개를 작성함
댓글 3개
I have horizontal lines that appear for a split second on my screen at random times . Pushing the screen makes the lines appear also. I think I might have dropped my laptop , which may have caused this. Would changing the screen fix this?
aarondhesi - 답글
Hi, i have the same problem. did it work for you?
Another Backup -
It should! When we looked into troubleshooting this, changing the screen can help with the lines you're seeing.
Samantha Postma - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 13
전체 시간: 3,567
