주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement
필요한 것
  1. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 4 단계, 이미지 1개 중 1개
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: 5 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: 5 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Trackpad: 8 단계, 이미지 1개 중 1개
    • Remove the strip of tape that secures the motherboard connector to the track pad.
  9. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 9 단계, 이미지 1개 중 1개
    • Unclip the motherboard connector from the track pad.
  10. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the strip of electrical tape from across the top of the track pad.
  11. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 11 단계, 이미지 1개 중 1개
    • Remove three 4 mm JIS #0 screws from the top of the track pad.
  12. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the laptop base and the track pad will come out from the front of the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Samantha Postma
회원 가입일: 10/15/19
1,238 평판
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 12
전체 시간: 1,013
