주요 콘텐츠로 건너뛰기
Acer Chromebook 15 CB5-571-C09S Fan Replacement
필요한 것
  1. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: 5 단계, 이미지 3개 중 1개 Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: 5 단계, 이미지 3개 중 2개 Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: 5 단계, 이미지 3개 중 3개
    • The fan is located at the top of the device enclosed by a grey plastic covering and is attached to the motherboard by a piece of brass colored metal.
    • Unscrew the four 3 mm PH00 Phillips screws located on the corner edges of the brass colored piece of metal.
  6. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the two 4 mm PH00 Phillips head screws on either side of the the fan.
    • Be aware that these screw are enclosed by small pieces of plastic and are not to be removed from the fan cover.
  7. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the fan connector from the motherboard using two plastic opening tools.
    • The fan connector is the white "plug" that connects the battery to the motherboard with yellow, white, red and black wires attached to it.
  8. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully unwrap the black and white wires from around the fan cover.
    • Be careful not to remove the wires from the Intel Dual Band Wireless-AC 7260 ports located just beneath the fan connector.
  9. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Grab the fan by its cover and the brass colored piece of metal and carefully lift up and pull out the fan from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sakiynah Howard
회원 가입일: 10/17/17
1,000 평판
안내서 6개를 작성함
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G3
3 회원들
안내서 12개를 작성함
댓글 한 개
Thanks for the guide. I was able to successfully replace my fan using it. I would like to point out a couple of things:
1. 10 minutes is not a realistic completion time for this guide.
2. Disconnecting the fan plug is challenging. It might have been easier with a small pair of pliers.
3. Since this guide involves dis/re-connecting the thermal interface between the processor and heat sink, you should be prepared to properly clean both surfaces and re-apply new thermal compound. There is an excellent guide on applying thermal compound here:
How to Apply Thermal Paste
Tristan Mackey - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 390
