주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2847 RAM Replacement
필요한 것
  1. Acer Chromebook C710-2847 RAM Replacement, Battery: 1 단계, 이미지 1/2 Acer Chromebook C710-2847 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 RAM Replacement: 2 단계, 이미지 1/2 Acer Chromebook C710-2847 RAM Replacement: 2 단계, 이미지 2/2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 RAM Replacement, Acer Chromebook C710-2847 Back Cover Replacement: 3 단계, 이미지 1/1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 RAM Replacement: 4 단계, 이미지 1/2 Acer Chromebook C710-2847 RAM Replacement: 4 단계, 이미지 2/2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 RAM Replacement, RAM: 5 단계, 이미지 1/2 Acer Chromebook C710-2847 RAM Replacement, RAM: 5 단계, 이미지 2/2
    • Pull the metal tabs sideways away from the memory stick.
    • The RAM stick will pop up.
  6. Acer Chromebook C710-2847 RAM Replacement: 6 단계, 이미지 1/2 Acer Chromebook C710-2847 RAM Replacement: 6 단계, 이미지 2/2
    • Pull the RAM stick up and away from the laptop.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Bradley Pavy
회원 가입일: 09/30/13
1,257 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 회원
CPSU-FORTE-F13S13G3
5 회원들
안내서 14개 작성하였습니다
댓글 7개
Is there only one RAM stick? My wife's C710 has 2 GB of RAM and I have two spare 2 GB sticks. I assumed that the C710 had two 1 GB sticks. Is this incorrect? Are two 2 GB sticks not going to help?
Garrett Mick - 답글
I believe the C710 comes with a single stick of RAM preinstalled, but there are two slots there. So if you have the correct type of RAM, you should be good to go. One installs right on top of the other.
Jeff Suovanen -
Awesome, thank you!
Garrett Mick - 답글
Acer and Crucial insist that 4 GB is maximum ram, but I’ve successfully installed 12 GB and I’ve read reports on the web of 16 GB. It uses the same memory as my 2012 Mac Mini, (my source for the additional RAM) Adding a SSD will make this a powerful machine indeed. The main limitation is that although it will run the (aging) Chrubuntu (an Ubuntu install running on the Chrome kernel), it will not dual boot with linux. The firmware needs to be flashed in order to install a newer linux distro (Gallium OS or a specialized Mint 18), and this will effectively end it’s ability to run Chrome (although I beleive the firmware can be re-flashed so as to return it to Chrome OS .)
cuvtixo - 답글
I want to change the ram stick up to 16 GB ram stick.
How?
flip - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 32
전체 시간: 13,200
