주요 콘텐츠로 건너뛰기
Acer Chromebook C732 Battery Replacement
필요한 것
  1. Acer Chromebook C732 Battery Replacement, Opening up your device: 1 단계, 이미지 1/2 Acer Chromebook C732 Battery Replacement, Opening up your device: 1 단계, 이미지 2/2
    • Flip the computer over, and using a Phillips #1 screwdriver, remove all 12 bottom cover screws.
    • Once all the screws are removed, place both pointer fingers between the screen hinges and the case and carefully pry the case away from the hinges.
  2. Acer Chromebook C732 Battery Replacement, Remove the ESD tape: 2 단계, 이미지 1/2 Acer Chromebook C732 Battery Replacement, Remove the ESD tape: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Once the back cover is removed, you will see that the battery is only held in place with a piece of ESD Tape. Using a set of tweezers, carefully peel away the tape from one end.
  3. Acer Chromebook C732 Battery Replacement, Disconnect your battery: 3 단계, 이미지 1/1
    • Once the tape is removed, you can use the pointed end of a Spudger or your fingernails and carefully unplug the battery from the logic board.
  4. Acer Chromebook C732 Battery Replacement, Remove your old battery: 4 단계, 이미지 1/1
    • The battery can now be removed.
    • To install the new battery, follow these steps in reverse order.
결론
The device will be in a battery disconnected state. This means that the device will not simply power on once the battery is reconnected. To bring the device out of storage mode, plug the device into a charger and a power source. You can then power on the device like normal.
다른 3명이 해당 안내서를 완성하였습니다.
Jacob Mehnert
회원 가입일: 10/18/21
28,615 평판
안내서 43개 작성하였습니다
iFanatics iFanatics 회원
Community
55 회원들
안내서 158개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 497
