주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-111-C670 Battery Replacement
필요한 것
  1. Acer Chromebook CB3-111-C670 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Acer Chromebook CB3-111-C670 Battery Replacement: 2 단계, 이미지 1/1
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Acer Chromebook CB3-111-C670 Battery Replacement: 3 단계, 이미지 1/1
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Acer Chromebook CB3-111-C670 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Tony
회원 가입일: 01/20/16
459 평판
안내서 2개 작성하였습니다
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 4,075
