이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The Acer Chromebook CB3-111-C670 uses an Intel WLAN Wireless Board 7260NGW. This guide will teach you how to disassemble your Chromebook and replace the WLAN chip.
필요한 것
Turn the Chromebook over so that the back panel with the tag and serial number is facing upward.
Locate the twelve screws and unscrew them using your nut/screw driver.
After removing each of the twelve screws, use a plastic opening tool to detach the back panel by inserting it in between crease where the back panel and the main board meets. You should hear a slight click, this is the sound of the back panel becoming detached from the board.
The best way to do this is to start at one of the four corners of the Chromebook and gently work around the edges. Be careful not to apply too much force or else you might damage the ribbon cable which connects the back panel to the motherboard.
Once you have detached the back panel, do not lift it vertically from the Chromebook. With the Chromebook facing in the direction of the picture above, take the outer right hand side of the back panel and lift it toward the left as if you are opening the front cover of a book.
Locate the WLAN chip near the top left corner of the motherboard. It is connected to the left edge of the motherboard and has two smaller wires connected to the wireless adapter itself.
First, grasp the top and bottom edge of chip using your fingers and gently disconnect it from the motherboard.
TheWLAN chip has two small wires connected to it, which can be disconnected from the card by pulling them very gently.
다른 4명이 해당 안내서를 완성하였습니다.
