주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-532-C47C Keyboard Keys Replacement
필요한 것
  1. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement, Keyboard Keys: 1 단계, 이미지 1개 중 1개
    • Place the plastic opening tool directly underneath the key and pry upwards to remove the key.
    • Do not use too much force to avoid separating the retainer clip on the keyboard.
  2. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement: 2 단계, 이미지 1개 중 1개
    • Repeat with each key that needs to be removed.
    • If you are removing the keys in order to clean the keyboard, please refer to the troubleshooting guide to complete this process.
결론
To reassemble your device, press the keys back onto the keyboard so that the figures are facing you.
작성자
1다른 기여자 명과 함께
Sadie Brown
회원 가입일: 10/25/21
967 평판
안내서 7개를 작성함
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G2
3 회원들
안내서 7개를 작성함
댓글 한 개
1 key has different commands. D key redirects to download, E key highlights and deletes texts and replaces it with Q, number 3 key types lots of numbers, C key types lots of letters. How can I fix this and what coulf be the possible cause of this?
Ryo Heil - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 31
전체 시간: 359
