주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-532-C47C Motherboard Replacement
필요한 것
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: 2 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: 3 단계, 이미지 1/1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: 4 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: 4 단계, 이미지 2/2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: 5 단계, 이미지 1/3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: 5 단계, 이미지 2/3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: 5 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: 6 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: 6 단계, 이미지 2/2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: 7 단계, 이미지 1/3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: 7 단계, 이미지 2/3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: 7 단계, 이미지 3/3
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: 8 단계, 이미지 1/3 Acer Chromebook CB3-532-C47C Motherboard Replacement: 8 단계, 이미지 2/3 Acer Chromebook CB3-532-C47C Motherboard Replacement: 8 단계, 이미지 3/3
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: 9 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: 10 단계, 이미지 1/1
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sadie Brown
회원 가입일: 10/25/21
967 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 27
전체 시간: 622
