주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-532-C47C Speaker Replacement
필요한 것
  1. Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Speaker Replacement: 2 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Speaker Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Speaker Replacement, Remove the battery cable: 3 단계, 이미지 1/1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: 4 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: 4 단계, 이미지 2/2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  5. Acer Chromebook CB3-532-C47C Speaker Replacement, Speakers: 5 단계, 이미지 1/1
    • Pry the right speaker up with your hand to remove.
  6. Acer Chromebook CB3-532-C47C Speaker Replacement: 6 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Speaker Replacement: 6 단계, 이미지 2/2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  7. Acer Chromebook CB3-532-C47C Speaker Replacement: 7 단계, 이미지 1/1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
결론
Sadie Brown
회원 가입일: 10/25/21
967 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 152
