주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-532-C47C Touchpad Replacement
필요한 것
  1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Touchpad Replacement: 2 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Touchpad Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Touchpad Replacement, Remove the battery cable: 3 단계, 이미지 1/1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: 4 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: 4 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Touchpad Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the laptop.
  6. Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: 6 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: 6 단계, 이미지 2/2
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  7. Acer Chromebook CB3-532-C47C Touchpad Replacement: 7 단계, 이미지 1/1
    • Pull the ribbon from the motherboard laterally off the touchpad.
  8. Acer Chromebook CB3-532-C47C Touchpad Replacement: 8 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  9. Acer Chromebook CB3-532-C47C Touchpad Replacement: 9 단계, 이미지 1/3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 9 단계, 이미지 2/3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 9 단계, 이미지 3/3
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  10. Acer Chromebook CB3-532-C47C Touchpad Replacement: 10 단계, 이미지 1/3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 10 단계, 이미지 2/3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 10 단계, 이미지 3/3
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
결론
Sadie Brown
회원 가입일: 10/25/21
967 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 239
