주요 콘텐츠로 건너뛰기
Acer Chromebook CB5-132T-C8ZW Speakers Replacement
필요한 것
  1. Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
  2. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
    • Do not immediately remove the back from the laptop. The power strip keeps the backing attached to the rest of the laptop. Gently lift backing from the power button side and set next to the body of the laptop.
  3. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Remove two 4.6 mm JIS # screws at each end of the battery.
  4. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
    • Remove the battery.
  5. Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Speakers: 5 단계, 이미지 3개 중 1개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Speakers: 5 단계, 이미지 3개 중 2개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Speakers: 5 단계, 이미지 3개 중 3개
    • Lift the speakers up using a spudger.
  6. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the white strip up and slide the speaker underneath.
  7. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 7 단계, 이미지 2개 중 2개
    • Slide the speaker through the black power strip.
    • A plastic spudger may be helpful to hold the power strip up.
  8. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 8 단계, 이미지 3개 중 1개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 8 단계, 이미지 3개 중 2개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the black tape that holds the wire in place using precision tweezers.
    • Unhook the wire from the small hooks that hold the wire in place.
  9. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 9 단계, 이미지 3개 중 1개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 9 단계, 이미지 3개 중 2개 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: 9 단계, 이미지 3개 중 3개
    • Disconnect the black connective piece using tweezers.
    • Lift the second speaker up using a plastic spudger tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lauren Reichenbach
회원 가입일: 01/13/20
580 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 245
