주요 콘텐츠로 건너뛰기
Acer Iconia A110 On/Off Switch Replacement
필요한 것
  1. Acer Iconia A110 On/Off Switch Replacement, Battery: 1 단계, 이미지 1/2 Acer Iconia A110 On/Off Switch Replacement, Battery: 1 단계, 이미지 2/2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 On/Off Switch Replacement: 2 단계, 이미지 1/3 Acer Iconia A110 On/Off Switch Replacement: 2 단계, 이미지 2/3 Acer Iconia A110 On/Off Switch Replacement: 2 단계, 이미지 3/3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 On/Off Switch Replacement: 3 단계, 이미지 1/3 Acer Iconia A110 On/Off Switch Replacement: 3 단계, 이미지 2/3 Acer Iconia A110 On/Off Switch Replacement: 3 단계, 이미지 3/3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
  4. Acer Iconia A110 On/Off Switch Replacement, Speaker: 4 단계, 이미지 1/2 Acer Iconia A110 On/Off Switch Replacement, Speaker: 4 단계, 이미지 2/2
    • With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
    • Two 2.0 mm screws (with the bigger head)
    • Four 2.5 mm screws (with the smaller head)
  5. Acer Iconia A110 On/Off Switch Replacement: 5 단계, 이미지 1/2 Acer Iconia A110 On/Off Switch Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
    • The vibration motor is still connected to the motherboard by a small wire connection, so be careful not to rip the wire out.
    • With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
  6. Acer Iconia A110 On/Off Switch Replacement: 6 단계, 이미지 1/2 Acer Iconia A110 On/Off Switch Replacement: 6 단계, 이미지 2/2
    • The speaker located on the top of the motherboard should easily slide out. Take note that there is still a wire connected, so do so carefully.
    • With your fingers, slowly pull out the wire connecting the speaker to the motherboard.
  7. Acer Iconia A110 On/Off Switch Replacement, Motherboard: 7 단계, 이미지 1/3 Acer Iconia A110 On/Off Switch Replacement, Motherboard: 7 단계, 이미지 2/3 Acer Iconia A110 On/Off Switch Replacement, Motherboard: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • The next step is to pull out the ribbon cables connected to the motherboard.
    • Each ribbon cable has a sticker covering it; peel it off with tweezers.
    • Use tweezers to pull out the ribbon cable.
    • Make sure to pull the ribbon cable horizontally, not vertically to avoid tearing the ribbon
  8. Acer Iconia A110 On/Off Switch Replacement: 8 단계, 이미지 1/3 Acer Iconia A110 On/Off Switch Replacement: 8 단계, 이미지 2/3 Acer Iconia A110 On/Off Switch Replacement: 8 단계, 이미지 3/3
    • After all ribbon cables are disconnected,move them out of the way, and the motherboard should fall out easily.
  9. Acer Iconia A110 On/Off Switch Replacement, On/Off Switch: 9 단계, 이미지 1/3 Acer Iconia A110 On/Off Switch Replacement, On/Off Switch: 9 단계, 이미지 2/3 Acer Iconia A110 On/Off Switch Replacement, On/Off Switch: 9 단계, 이미지 3/3
    • After the motherboard is removed, the buttons are visible on the side.
    • If you do not have soldering experience, STOP HERE. View this link for an ifixit soldering guide.
    • Use a soldering iron and a soldering wick to desolder the button. This could be tough due to the lead free solder used in the manufacturing process.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Andrea
회원 가입일: 04/14/14
757 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-42, Maness Spring 2014 Cal Poly, Team 3-42, Maness Spring 2014 회원
CPSU-MANESS-S14S3G42
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 3,089
