주요 콘텐츠로 건너뛰기
Acer Predator 17 G9-791 Fan Assembly Replacement
필요한 것
  1. Acer Predator 17 G9-791 Fan Assembly Replacement, Service Panel: 1 단계, 이미지 1개 중 1개
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Fan Assembly Replacement: 2 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Fan Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Fan Assembly Replacement, Bottom Case: 4 단계, 이미지 3개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement, Bottom Case: 4 단계, 이미지 3개 중 2개 Acer Predator 17 G9-791 Fan Assembly Replacement, Bottom Case: 4 단계, 이미지 3개 중 3개
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Fan Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Fan Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Fan Assembly Replacement: 7 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Fan Assembly Replacement, Battery: 8 단계, 이미지 1개 중 1개
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Fan Assembly Replacement: 9 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Fan Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • Gently lift the battery and remove it from the device.
  11. Acer Predator 17 G9-791 Fan Assembly Replacement, Fan Assembly: 11 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement, Fan Assembly: 11 단계, 이미지 2개 중 2개
    • Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
  12. Acer Predator 17 G9-791 Fan Assembly Replacement: 12 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Unscrew the six Phillips #0 screws enough to loosen the assembly from the motherboard.
  13. Acer Predator 17 G9-791 Fan Assembly Replacement: 13 단계, 이미지 3개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement: 13 단계, 이미지 3개 중 2개 Acer Predator 17 G9-791 Fan Assembly Replacement: 13 단계, 이미지 3개 중 3개
    • Detach the left fan's cord from the motherboard.
  14. Acer Predator 17 G9-791 Fan Assembly Replacement: 14 단계, 이미지 3개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement: 14 단계, 이미지 3개 중 2개 Acer Predator 17 G9-791 Fan Assembly Replacement: 14 단계, 이미지 3개 중 3개
    • Detach the right fan's cord from the motherboard.
  15. Acer Predator 17 G9-791 Fan Assembly Replacement: 15 단계, 이미지 3개 중 1개 Acer Predator 17 G9-791 Fan Assembly Replacement: 15 단계, 이미지 3개 중 2개 Acer Predator 17 G9-791 Fan Assembly Replacement: 15 단계, 이미지 3개 중 3개
    • Lift the fan assembly up and out.
결론
작성자
4다른 기여자 명과 함께
Grant Maffei
회원 가입일: 10/25/22
121 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S5G1
5 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 22
전체 시간: 605
