주요 콘텐츠로 건너뛰기
Acer Predator Helios PH315-51 RAM Replacement
필요한 것
  1. Acer Predator Helios PH315-51 RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over.
    • There are two panels on the back. The smallest is the RAM panel.
  2. Acer Predator Helios PH315-51 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single screw holding the panel using a Phillips #1 screwdriver.
    • Use your fingernail to remove the panel.
  3. Acer Predator Helios PH315-51 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Push the clip down and move it left.
    • Push the clip down and move it right.
  4. Acer Predator Helios PH315-51 RAM Replacement: 4 단계, 이미지 2개 중 1개 Acer Predator Helios PH315-51 RAM Replacement: 4 단계, 이미지 2개 중 2개
    • The RAM should pop up when clips are moved.
    • Remove the RAM.
    • The RAM should easily be removed from the pins making sure no damage is done to the pins.
  5. Acer Predator Helios PH315-51 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Before inserting the new RAM, make sure there are more pins on the left side of the new RAM before the space in between so that the RAM goes in the slot correctly.
    • When the RAM is inserted, push it down and the hinges will automatically hold the RAM in its place.
    • Make sure to not apply pressure to any part. Everything should be done with care and ease.
  6. Acer Predator Helios PH315-51 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Close the panel by using the Phillips #1 screwdriver.
결론
To make sure everything works correctly, power ON the laptop. It will take longer than usual to boot up because the RAM is initializing itself. When the laptop turns ON, go to about Your PC section and there you will see installed RAM and now your laptop is ready to use.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Aakarshak Jain
회원 가입일: 07/26/23
260 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 31
전체 시간: 743
