주요 콘텐츠로 건너뛰기
Acer Spin 5 SP515-51GN-807G Battery Replacement
필요한 것
  1. Acer Spin 5 SP515-51GN-807G Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Battery Replacement: 2 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Battery Replacement: 2 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Battery Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Battery Replacement: 3 단계, 이미지 1/1
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: 4 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: 4 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Battery Replacement: 5 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Battery Replacement: 5 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Battery Replacement: 5 단계, 이미지 3/3
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Battery Replacement: 6 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Battery Replacement: 6 단계, 이미지 2/2
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Battery Replacement: 7 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Battery Replacement: 7 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Battery Replacement: 7 단계, 이미지 3/3
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Battery Replacement: 8 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Battery Replacement: 8 단계, 이미지 2/2
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
결론
James Wasielewski
회원 가입일: 01/24/20
1,042 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 58
전체 시간: 1,345
