주요 콘텐츠로 건너뛰기
Acer Swift 3 2022 Screen Replacement
필요한 것
  1. Acer Swift 3 2022 Screen Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Screen Replacement: 2 단계, 이미지 2개 중 1개 Acer Swift 3 2022 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: 4 단계, 이미지 3개 중 1개 Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: 4 단계, 이미지 3개 중 2개 Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: 4 단계, 이미지 3개 중 3개
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Screen Replacement: 5 단계, 이미지 2개 중 1개 Acer Swift 3 2022 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 Acer Swift 3 2022 Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 Acer Swift 3 2022 Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
    • Remove the EDP Cable located on the top right by pushing away from you.
  7. Acer Swift 3 2022 Screen Replacement: 7 단계, 이미지 3개 중 1개 Acer Swift 3 2022 Screen Replacement: 7 단계, 이미지 3개 중 2개 Acer Swift 3 2022 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the four 4.5 mm screws on the metal plates located on the top left and right hand corner using the JIS #1 screwdriver.
    • Flip up the metal plates.
    • The metal plates will be tight/hard to move.
  8. Acer Swift 3 2022 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Open computer to a 90 degree angle by lifting the keyboard and sliding it out.
    • Place keyboard to the side so the screen is face up and the only thing in front of you.
  9. Acer Swift 3 2022 Screen Replacement: 9 단계, 이미지 3개 중 1개 Acer Swift 3 2022 Screen Replacement: 9 단계, 이미지 3개 중 2개 Acer Swift 3 2022 Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Insert the spudger between the computer screen and the black bezel.
    • Slide around the whole perimeter of screen.
    • Peel the bezel off.
  10. Acer Swift 3 2022 Screen Replacement: 10 단계, 이미지 3개 중 1개 Acer Swift 3 2022 Screen Replacement: 10 단계, 이미지 3개 중 2개 Acer Swift 3 2022 Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Disconnect the other end of the EDP Cable located next to the camera with the spudger.
  11. Acer Swift 3 2022 Screen Replacement: 11 단계, 이미지 3개 중 1개 Acer Swift 3 2022 Screen Replacement: 11 단계, 이미지 3개 중 2개 Acer Swift 3 2022 Screen Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the curved, fine-tipped tweezers, unstick the tape from the top of the case.
    • Once the tape is unstuck, pinch it with the tweezers and pull in the opposite direction.
    • Repeat on the other side.
    • The tape will stretch. You might have to regrip it.
    • You may only do this once. The tape will no longer be effective.
  12. Acer Swift 3 2022 Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Remove screen.
    • There will be some wires connected to the bottom of the screen. Pull them out carefully with the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Anna Miller
회원 가입일: 09/26/22
927 평판
안내서 6개를 작성함
Utah Tech University, Team 1-2, McMurrin Fall 2022 Utah Tech University, Team 1-2, McMurrin Fall 2022 회원
UTAHTECH-MCMURRIN-F22S1G2
2 회원들
안내서 6개를 작성함
1가이드 댓글
really good i just followed the instructions and it was easy to do.
Sanchoi Dacres - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 98
전체 시간: 4,350
