주요 콘텐츠로 건너뛰기
Acer Swift 3 2022 Speakers Replacement
필요한 것
  1. Acer Swift 3 2022 Speakers Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Speakers Replacement: 2 단계, 이미지 2개 중 1개 Acer Swift 3 2022 Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Speakers Replacement, How to Unplug the Battery: 4 단계, 이미지 3개 중 1개 Acer Swift 3 2022 Speakers Replacement, How to Unplug the Battery: 4 단계, 이미지 3개 중 2개 Acer Swift 3 2022 Speakers Replacement, How to Unplug the Battery: 4 단계, 이미지 3개 중 3개
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Speakers Replacement: 5 단계, 이미지 2개 중 1개 Acer Swift 3 2022 Speakers Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 1개 Acer Swift 3 2022 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 2개
    • With the iFixit opening tool or your nail, gently lift the speaker up near the bottom attachment site.
  7. Acer Swift 3 2022 Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Pinch the end of the speaker to gently slide the the other end out towards you while still being attached to the white plastic piece.
  8. Acer Swift 3 2022 Speakers Replacement: 8 단계, 이미지 2개 중 1개 Acer Swift 3 2022 Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Remove tape overlaying the wires.
  9. Acer Swift 3 2022 Speakers Replacement: 9 단계, 이미지 2개 중 1개 Acer Swift 3 2022 Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • With your two fingernails, place them on both sides of the upside-down "T" and pull towards yourself.
    • Be careful removing this piece; it can be damaged by removing it at a bad angle. Pull straight back.
  10. Acer Swift 3 2022 Speakers Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the speaker.
    • Repeat for the other side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Anna Miller
회원 가입일: 09/26/22
927 평판
안내서 6개를 작성함
Utah Tech University, Team 1-2, McMurrin Fall 2022 Utah Tech University, Team 1-2, McMurrin Fall 2022 회원
UTAHTECH-MCMURRIN-F22S1G2
2 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 30
전체 시간: 1,240
