주요 콘텐츠로 건너뛰기
Acer Swift X N20C12 Heatsink Replacement
필요한 것
  1. Acer Swift X N20C12 Heatsink Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Heatsink Replacement: 2 단계, 이미지 1개 중 1개
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Heatsink Replacement, Heatsink: 3 단계, 이미지 2개 중 1개 Acer Swift X N20C12 Heatsink Replacement, Heatsink: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the five 5 mm screws that secure the heatsink.
    • When reinstalling the heatsink, replace the screws in the numbered order as indicated on the heatsink.
  4. Acer Swift X N20C12 Heatsink Replacement: 4 단계, 이미지 1개 중 1개
    • Hold the heatsink firmly with your fingers and lift it straight up to remove it from the laptop.
  5. Acer Swift X N20C12 Heatsink Replacement: 5 단계, 이미지 2개 중 1개 Acer Swift X N20C12 Heatsink Replacement: 5 단계, 이미지 2개 중 2개
    • Lay the heatsink with the thermal paste up so you don't stain your surface.
    • Instead of replacing, if you want to repaste the laptop, clean the thermal paste and pads off of the heatsink and motherboard components with isopropyl alcohol. Follow this guide for more information.
    • When applying the thermal paste/pads on the motherboard components, making sure not to apply too much or little. Do NOT apply the thermal paste/pads on the heatsink.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hector
회원 가입일: 06/17/25
427 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 98
