주요 콘텐츠로 건너뛰기
Afterglow Wireless PS3 Controller Battery Replacement
필요한 것
  1. Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Battery Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use the soldering tool to heat the solder connecting the battery wires to the motherboard.
    • The soldering gun will loosen the bonds of the solder allowing the wires to be detached. Use this guide for further details on how to solder.
결론
작성자
3다른 기여자 명과 함께
Aj Coello
회원 가입일: 02/17/17
1,014 평판
안내서 6개를 작성함
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G5
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 76
전체 시간: 3,564
