주요 콘텐츠로 건너뛰기
Afterglow Wireless PS3 Controller Motherboard Replacement
필요한 것
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: 2 단계, 이미지 1개 중 1개
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
결론
작성자
3다른 기여자 명과 함께
Natalie Cox
회원 가입일: 02/17/17
207 평판
안내서 2개를 작성함
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G5
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 35
전체 시간: 1,553
