주요 콘텐츠로 건너뛰기
Air Hog Smash Bots Motherboard Replacement
필요한 것
  1. Air Hog Smash Bots Motherboard Replacement, Batteries: 1 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Motherboard Replacement: 2 단계, 이미지 1/1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Motherboard Replacement, External Casing: 4 단계, 이미지 1/2 Air Hog Smash Bots Motherboard Replacement, External Casing: 4 단계, 이미지 2/2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Motherboard Replacement: 5 단계, 이미지 1/2 Air Hog Smash Bots Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Motherboard Replacement: 6 단계, 이미지 1/1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Motherboard Replacement: 7 단계, 이미지 1/1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Motherboard Replacement: 8 단계, 이미지 1/2 Air Hog Smash Bots Motherboard Replacement: 8 단계, 이미지 2/2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Air Hog Smash Bots Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Remove four 4.75mm screws from the motherboard.
  10. Air Hog Smash Bots Motherboard Replacement: 10 단계, 이미지 1/2 Air Hog Smash Bots Motherboard Replacement: 10 단계, 이미지 2/2
    • Use the soldering iron to remove the two wires from the motherboard. Directions on how to solder can be found here.
  11. Air Hog Smash Bots Motherboard Replacement: 11 단계, 이미지 1/1
    • Use the spudger to pry the motherboard away from the robot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brittany Frecker
회원 가입일: 02/08/16
542 평판
안내서 4개 작성하였습니다
IUPUI, Team 1-1, Baechle Spring 2016 IUPUI, Team 1-1, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G1
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 229
