주요 콘텐츠로 건너뛰기
Alcatel Fierce 4 Display Replacement
필요한 것
  1. Alcatel Fierce 4 Display Replacement, Battery: 1 단계, 이미지 1/1
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Alcatel Fierce 4 Display Replacement: 2 단계, 이미지 1/2 Alcatel Fierce 4 Display Replacement: 2 단계, 이미지 2/2
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Alcatel Fierce 4 Display Replacement: 3 단계, 이미지 1/1
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Alcatel Fierce 4 Display Replacement: 4 단계, 이미지 1/2 Alcatel Fierce 4 Display Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Alcatel Fierce 4 Display Replacement: 5 단계, 이미지 1/1
    • Remove the motherboard from the phone.
  6. Alcatel Fierce 4 Display Replacement: 6 단계, 이미지 1/1
    • Carefully pry up the battery with a plastic opening tool, or your hands.
  7. Alcatel Fierce 4 Display Replacement, Display: 7 단계, 이미지 1/1
    • Replace with new display assembly.
결론
Mckenzie Dalley
회원 가입일: 11/04/19
73 평판
안내서 1개 작성함
Idaho State University, Team S1-G1, Watkins Fall 2019 Idaho State University, Team S1-G1, Watkins Fall 2019 회원
ISU-WATKINS-F19S1G1
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 300
