주요 콘텐츠로 건너뛰기
Alcatel Jitterbug Smart Headphone Jack Replacement
필요한 것
  1. Alcatel Jitterbug Smart Headphone Jack Replacement, Battery: 1 단계, 이미지 1/2 Alcatel Jitterbug Smart Headphone Jack Replacement, Battery: 1 단계, 이미지 2/2
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
  2. Alcatel Jitterbug Smart Headphone Jack Replacement: 2 단계, 이미지 1/3 Alcatel Jitterbug Smart Headphone Jack Replacement: 2 단계, 이미지 2/3 Alcatel Jitterbug Smart Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
  3. Alcatel Jitterbug Smart Headphone Jack Replacement: 3 단계, 이미지 1/2 Alcatel Jitterbug Smart Headphone Jack Replacement: 3 단계, 이미지 2/2
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
  4. Alcatel Jitterbug Smart Headphone Jack Replacement: 4 단계, 이미지 1/2 Alcatel Jitterbug Smart Headphone Jack Replacement: 4 단계, 이미지 2/2
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Alcatel Jitterbug Smart Headphone Jack Replacement, Motherboard: 5 단계, 이미지 1/3 Alcatel Jitterbug Smart Headphone Jack Replacement, Motherboard: 5 단계, 이미지 2/3 Alcatel Jitterbug Smart Headphone Jack Replacement, Motherboard: 5 단계, 이미지 3/3
    • Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
  6. Alcatel Jitterbug Smart Headphone Jack Replacement: 6 단계, 이미지 1/2 Alcatel Jitterbug Smart Headphone Jack Replacement: 6 단계, 이미지 2/2
    • Use a pair of tweezers to pull the black ribbon connector from its port.
    • Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Be careful to avoid damage the black connector or the wire connect the speaker to motherboard.
  7. Alcatel Jitterbug Smart Headphone Jack Replacement: 7 단계, 이미지 1/2 Alcatel Jitterbug Smart Headphone Jack Replacement: 7 단계, 이미지 2/2
    • Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
    • The motherboard will freely remove.
  8. Alcatel Jitterbug Smart Headphone Jack Replacement, Headphone Jack: 8 단계, 이미지 1/2 Alcatel Jitterbug Smart Headphone Jack Replacement, Headphone Jack: 8 단계, 이미지 2/2
    • Flip the motherboard upside-down and desolder the pin connection of headphone jack to the motherboard.
    • Once pins desolder, pull the headphone jack out.
    • If you need helps on solder/desolder, here is the line to the soldering skills guide.
결론
Minyu Zhang
회원 가입일: 02/13/18
181 평판
안내서 2개 작성하였습니다
USF Tampa, Team S11-G4, Cheng Spring 2018 USF Tampa, Team S11-G4, Cheng Spring 2018 회원
USFT-CHENG-S18S11G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 202
