주요 콘텐츠로 건너뛰기
Alcatel Pop 4 Plus Charging Port Replacement
필요한 것
  1. Alcatel Pop 4 Plus Charging Port Replacement, Charging Port: 1 단계, 이미지 1/3 Alcatel Pop 4 Plus Charging Port Replacement, Charging Port: 1 단계, 이미지 2/3 Alcatel Pop 4 Plus Charging Port Replacement, Charging Port: 1 단계, 이미지 3/3
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Charging Port Replacement: 2 단계, 이미지 1/3 Alcatel Pop 4 Plus Charging Port Replacement: 2 단계, 이미지 2/3 Alcatel Pop 4 Plus Charging Port Replacement: 2 단계, 이미지 3/3
    • Remove seventeen 1.2 mm screws from the phone's mid-frame using the Phillips #000 screwdriver.
  3. Alcatel Pop 4 Plus Charging Port Replacement: 3 단계, 이미지 1/2 Alcatel Pop 4 Plus Charging Port Replacement: 3 단계, 이미지 2/2
    • Once the screws have been taken out, remove the mid-frame protecting the phone's electronics by using a fingernail or tool to pry it off.
  4. Alcatel Pop 4 Plus Charging Port Replacement: 4 단계, 이미지 1/2 Alcatel Pop 4 Plus Charging Port Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery from the motherboard and remove it.
  5. Alcatel Pop 4 Plus Charging Port Replacement: 5 단계, 이미지 1/2 Alcatel Pop 4 Plus Charging Port Replacement: 5 단계, 이미지 2/2
    • Unhook the USB ribbon from the motherboard.
  6. Alcatel Pop 4 Plus Charging Port Replacement: 6 단계, 이미지 1/2 Alcatel Pop 4 Plus Charging Port Replacement: 6 단계, 이미지 2/2
    • Disconnect the phone's ribbon cable.
  7. Alcatel Pop 4 Plus Charging Port Replacement: 7 단계, 이미지 1/2 Alcatel Pop 4 Plus Charging Port Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbon cable from the phone
  8. Alcatel Pop 4 Plus Charging Port Replacement: 8 단계, 이미지 1/2 Alcatel Pop 4 Plus Charging Port Replacement: 8 단계, 이미지 2/2
    • Remove the phone's rear camera from the motherboard.
  9. Alcatel Pop 4 Plus Charging Port Replacement: 9 단계, 이미지 1/1
    • Use the flat end of the spudger to pry off the motherboard.
  10. Alcatel Pop 4 Plus Charging Port Replacement: 10 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anna Gongre
회원 가입일: 09/20/19
319 평판
안내서 2개 작성하였습니다
댓글 한 개
Hello, nice to meet you. I like your guide because it is didactic and objective in the apprehension process. I would like to support me in the visualization to buy the charging port. Alcatel pop 4 plus 5056e. Thank you
Carlos Reboredo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 21
전체 시간: 694
