주요 콘텐츠로 건너뛰기
Alcatel Pop 4 Plus Headphone Jack Replacement
필요한 것
  1. Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/3 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 2/3 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 3/3
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Headphone Jack Replacement: 2 단계, 이미지 1/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 2 단계, 이미지 2/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Remove seventeen 1.2mm screws from the phone's mid-frame using the Phillips #000 screwdriver.
  3. Alcatel Pop 4 Plus Headphone Jack Replacement: 3 단계, 이미지 1/2 Alcatel Pop 4 Plus Headphone Jack Replacement: 3 단계, 이미지 2/2
    • Once the screws have been taken out, remove the mid-frame protecting the phone's electronics by using a fingernail or tool to pry it off.
  4. Alcatel Pop 4 Plus Headphone Jack Replacement: 4 단계, 이미지 1/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 4 단계, 이미지 2/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 4 단계, 이미지 3/3
    • Disconnect the battery from the motherboard and remove it.
  5. Alcatel Pop 4 Plus Headphone Jack Replacement: 5 단계, 이미지 1/2 Alcatel Pop 4 Plus Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Unhook the USB ribbon from the motherboard.
  6. Alcatel Pop 4 Plus Headphone Jack Replacement: 6 단계, 이미지 1/2 Alcatel Pop 4 Plus Headphone Jack Replacement: 6 단계, 이미지 2/2
    • Disconnect the phone's ribbon cable from the mother board.
  7. Alcatel Pop 4 Plus Headphone Jack Replacement: 7 단계, 이미지 1/2 Alcatel Pop 4 Plus Headphone Jack Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbon cable that binds the two motherboards together.
  8. Alcatel Pop 4 Plus Headphone Jack Replacement: 8 단계, 이미지 1/2 Alcatel Pop 4 Plus Headphone Jack Replacement: 8 단계, 이미지 2/2
    • Remove the phone's rear camera from the motherboard.
  9. Alcatel Pop 4 Plus Headphone Jack Replacement: 9 단계, 이미지 1/1
    • Insert a flat tool at the edge of the phone and gently lift to remove the motherboard.
  10. Alcatel Pop 4 Plus Headphone Jack Replacement: 10 단계, 이미지 1/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 10 단계, 이미지 2/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 10 단계, 이미지 3/3
    • Locate the phone's headphone jack on the motherboard.
  11. Alcatel Pop 4 Plus Headphone Jack Replacement: 11 단계, 이미지 1/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 11 단계, 이미지 2/3 Alcatel Pop 4 Plus Headphone Jack Replacement: 11 단계, 이미지 3/3
결론
Garett Marler
회원 가입일: 09/19/19
202 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 5
30일 전: 9
전체 시간: 158
