주요 콘텐츠로 건너뛰기
Alldaymall A88X Touch Sensor Replacement
필요한 것
  1. Alldaymall A88X Touch Sensor Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 3/3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Touch Sensor Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Touch Sensor Replacement, Speaker: 3 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement, Speaker: 3 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement, Speaker: 3 단계, 이미지 3/3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Touch Sensor Replacement: 4 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement: 4 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Touch Sensor Replacement: 5 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement: 5 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement: 5 단계, 이미지 3/3
    • Desolder the speaker wires from the motherboard.
  6. Alldaymall A88X Touch Sensor Replacement, Camera: 6 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement, Camera: 6 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement, Camera: 6 단계, 이미지 3/3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  7. Alldaymall A88X Touch Sensor Replacement: 7 단계, 이미지 1/2 Alldaymall A88X Touch Sensor Replacement: 7 단계, 이미지 2/2
    • Desolder the wires that connect the battery to the motherboard.
  8. Alldaymall A88X Touch Sensor Replacement: 8 단계, 이미지 1/2 Alldaymall A88X Touch Sensor Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
  9. Alldaymall A88X Touch Sensor Replacement: 9 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement: 9 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement: 9 단계, 이미지 3/3
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
  10. Alldaymall A88X Touch Sensor Replacement: 10 단계, 이미지 1/1
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
  11. Alldaymall A88X Touch Sensor Replacement: 11 단계, 이미지 1/1
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
  12. Alldaymall A88X Touch Sensor Replacement: 12 단계, 이미지 1/2 Alldaymall A88X Touch Sensor Replacement: 12 단계, 이미지 2/2
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
  13. Alldaymall A88X Touch Sensor Replacement, Motherboard: 13 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement, Motherboard: 13 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement, Motherboard: 13 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
    • Using a pair of tweezers remove the ribbon cable from its receptacle.
  14. Alldaymall A88X Touch Sensor Replacement: 14 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement: 14 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement: 14 단계, 이미지 3/3
    • Now on the left ribbon cable use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
  15. Alldaymall A88X Touch Sensor Replacement: 15 단계, 이미지 1/2 Alldaymall A88X Touch Sensor Replacement: 15 단계, 이미지 2/2
    • Desolder the wires that connect the backlight to the motherboard.
  16. Alldaymall A88X Touch Sensor Replacement: 16 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement: 16 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement: 16 단계, 이미지 3/3
    • Using a PH0 screw bit unscrew the three 3mm screws securing the motherboard to the back panel.
  17. Alldaymall A88X Touch Sensor Replacement: 17 단계, 이미지 1/1
    • Carefully lift up on the motherboard from its housing.
  18. Alldaymall A88X Touch Sensor Replacement, LCD Screen and Touch Sensor Assembly: 18 단계, 이미지 1/3 Alldaymall A88X Touch Sensor Replacement, LCD Screen and Touch Sensor Assembly: 18 단계, 이미지 2/3 Alldaymall A88X Touch Sensor Replacement, LCD Screen and Touch Sensor Assembly: 18 단계, 이미지 3/3
    • Gently pry the brackets holding the touch sensor to the LCD Screen
    • Do not bend the touch sensor to much as it may shatter.
  19. Alldaymall A88X Touch Sensor Replacement, Touch Sensor: 19 단계, 이미지 1/2 Alldaymall A88X Touch Sensor Replacement, Touch Sensor: 19 단계, 이미지 2/2
    • Set the LCD Screen aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Drhaber
회원 가입일: 02/10/16
985 평판
안내서 7개 작성하였습니다
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 회원
USFT-LACY-S16S4G1
4 회원들
안내서 16개 작성하였습니다
댓글 2개
Fantastic guide!
Corey - 답글
Great work on me snaping the clips
Ecocat - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 566
