소개
Electrolytic capacitors are electronic components used to store energy. If too much current runs through a capacitor, it may become bulged and need to be replaced. To replace a capacitor on the MRV-M500 you will need previous experience soldering electronics. To learn how to solder, see this guide.
필요한 것
Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
다른 3명이 해당 안내서를 완성하였습니다.
