주요 콘텐츠로 건너뛰기
Alpine MRV-M500 Electrolytic Capacitor Replacement
필요한 것
  1. Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: 1 단계, 이미지 1/3 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: 1 단계, 이미지 2/3 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: 1 단계, 이미지 3/3
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  2. Alpine MRV-M500 Electrolytic Capacitor Replacement: 2 단계, 이미지 1/3 Alpine MRV-M500 Electrolytic Capacitor Replacement: 2 단계, 이미지 2/3 Alpine MRV-M500 Electrolytic Capacitor Replacement: 2 단계, 이미지 3/3
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Remove the circuit board from the case.
  3. Alpine MRV-M500 Electrolytic Capacitor Replacement: 3 단계, 이미지 1/2 Alpine MRV-M500 Electrolytic Capacitor Replacement: 3 단계, 이미지 2/2
    • Find the faulty capacitor.
    • Flip the board over and locate the corresponding pins.
    • If the faulty capacitor is one of the smaller ones, it may be too difficult to replace and replacing the circuit board itself may be easier.
    • Make sure that the capacitance and voltage rating of the new capacitor match that of the original.
  4. Alpine MRV-M500 Electrolytic Capacitor Replacement: 4 단계, 이미지 1/1
    • Desolder the pins to remove the capacitor.
    • Solder the new capacitor into its place.
    • Make sure the polarity of the new capacitor matches the previous polarity.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Eric Gaulke
회원 가입일: 09/17/18
623 평판
안내서 3개 작성하였습니다
Washington State, Team S2-G6, Hope Fall 2018 Washington State, Team S2-G6, Hope Fall 2018 회원
WSU-HOPE-F18S2G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 1,550
