주요 콘텐츠로 건너뛰기
Altec Lansing inMotion iM9 Motherboard Replacement
필요한 것
  1. Altec Lansing inMotion iM9 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Motherboard Replacement, Volume and Power Buttons: 3 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement, Volume and Power Buttons: 3 단계, 이미지 2개 중 2개
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
  6. Altec Lansing inMotion iM9 Motherboard Replacement, Case Opening: 6 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement, Case Opening: 6 단계, 이미지 2개 중 2개
    • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
    • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
    • Remove the silver lining.
  7. Altec Lansing inMotion iM9 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
    • Once loose, lift up the metal mesh.
  8. Altec Lansing inMotion iM9 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
    • Remove the 7mm screw with the Phillips #1 Screwdriver.
  9. Altec Lansing inMotion iM9 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully separate the front and back case plates at a corner of the speaker.
    • Lots of cables are still connected, so be very gentle when separating case plates.
  10. Altec Lansing inMotion iM9 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Guide the white button cables through the hole on the top of speaker case.
  11. Altec Lansing inMotion iM9 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Use your fingers to peel the glue off of the red and black cables.
  12. Altec Lansing inMotion iM9 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Careful not to touch the green capacitors or you might shock yourself.
  13. Altec Lansing inMotion iM9 Motherboard Replacement, Motherboard: 13 단계, 이미지 1개 중 1개
    • Using a Phillips #1 screwdriver, remove the two 7mm screws from the filter.
  14. Altec Lansing inMotion iM9 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Repeat the previous step on the other side of the speaker. There are two more 7mm screws on the filter mirroring the first.
    • Don't touch the green capacitors; you might get shocked.
  15. Altec Lansing inMotion iM9 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Don't touch the green capacitors. They might shock you.
  16. Altec Lansing inMotion iM9 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the four 10mm screws from the corners of the motherboard.
  17. Altec Lansing inMotion iM9 Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • On the back side of the motherboard, pry out the connector to the filter using the plastic spudger. You will have to use a lot of force.
    • Pry out the second connect to the filter similarly.
  18. Altec Lansing inMotion iM9 Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Desolder the two battery connections from the motherboard.
    • Do not touch capacitors to avoid being shocked.
  19. Altec Lansing inMotion iM9 Motherboard Replacement: 19 단계, 이미지 1개 중 1개
    • Use the pointed end of the plastic spudger to pry the glue off of the iPod dock. You will probably have to use some force.
  20. Altec Lansing inMotion iM9 Motherboard Replacement: 20 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    • Unlock the ribbon cable dock by pressing down on the two tabs at the bottom of the dock.
    • Detach the copper ribbon cable by gently pulling it down, freeing the motherboard completely.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kirsten Mork
회원 가입일: 02/01/15
270 평판
안내서 2개를 작성함
Cal Poly, Team 17-33, Amido Winter 2015 Cal Poly, Team 17-33, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G33
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 1,083
