주요 콘텐츠로 건너뛰기
Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
필요한 것
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: 3 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: 3 단계, 이미지 2개 중 2개
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 4 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 5 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
결론
작성자
4다른 기여자 명과 함께
Ben Toland
회원 가입일: 02/01/15
101 평판
안내서 1개를 작성함
Cal Poly, Team 17-33, Amido Winter 2015 Cal Poly, Team 17-33, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G33
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 14
전체 시간: 2,618
